 :: Belkin 4-port PS/2 / USB KVM w/Audio
Specifications and other general information
System Requirements PS/2 or USB computers compatible and certified with Windows® 95, 98, 2000, NT, Me, Novell® NetWare 5, TurboLinux and all Linux® distributions.
In the Box
  • OmniView 4-Port SOHO Series KVM Switch with Audio, PS/2 and USB platform
  • Attachable Base
  • DB25 to RJ45 Serial Flash Cable
  • Two PS/2 Extension Cables
  • User Manual
  • Quick Installation Guide
Product Specifications and Features
  • Powered by the PS/2 Keyboard port, USB port, or Optional AC adapter
  • PCs Supported: 4
  • Keyboard Emulation: USB, PS/2
  • Mouse Input:6-pin miniDIN (PS/2)
  • Audio Input/output: 3.5-mm jack
  • Microphone input/output: 3.5-mm jack
  • VGA Port: 15-Pin HDDB Type
  • Supports video resolutions up to 2048x1536@85Hz through a 400MHz bandwidth
  • PC99 colored ports to make identification easy
  • Features hot key switching and direct-port access button
  • LED Indicators: 4
  • Flash upgrade firmware support
  • Enclosure: High impact plastic w/built in cable management system [marketing speak for a cover]
  • Dimensions: 7.75” x 4.75” x 9.5”
  • Weight: 2.0lbs
  • Operating Temp: 32° to 104° F
  • Storage Temp: -4° to 140° F
  • Humidity: 0-80% RH, non-condensing
  • Warranty:5 Years w/ free technical support
Pictures
