 :: CarPC Project Review
D-Link DWL-120 Air 2.4GHz Wireless USB Adapter
Product: DWL-120 Air 2.4GHz Wireless USB Adapter
Manufacturer: D-Link
Website: http://www.dlink.com
Price: $59.00 at D-Link Shop
Photos:
About:
The final key to connecting the wireless network up is a USB adapter for connection to the CarPC. What makes this device so great is that it is very compact, sleek and features a foldable antenna. This new product is definitely a nice improvement over the original DWL-120's that first came out.
Features and Specs:
  • Standards: IEEE 802.11b, Wi-Fi certified, USB 1.1
  • Host Interface: Mini USB to A-type
  • Data Rates With Automatic Fallback
  • Data Rates Supported: 11Mbps, 5.5Mbps, 2Mbps, 1Mbps
  • Encryption: 64-, 128-bit WEP
  • Media Access Control: CSMA/CA with ACK
  • Frequency Range: 2.4GHz to 2.462GHz
  • Range Up to 328 feet Indoors
  • Modulation: Direct Sequence Spread Spectrum
  • Modulation Techniques: CCK (11Mbps), CCK (5.5Mbps), DQPSK (2Mbps), DBSK (1Mbps)
  • Transmit Output Power: 19dBm (79mW) +-2dB
  • Receiver Sensitivity: -84dBm for 11Mbps@ 8% PER (Packet Error Rate), -90dBm for 2Mbps@ 8% PER (Packet Error Rate)
  • Operating Voltage: 5VDC +- 10%
  • Internal Antenna: Type Dual PIFA (Patched Inverse “F” Antenna)
  • Temperature Operating: -32°F to 131°F (0°C to 55°C)
  • Storing: -4°F to 167°F (20°C to 75°C)
  • Humidity 5% - 95% non-condensing
  • Dimensions: L=3.3 inches (85mm), W=2.2 inches (55mm), H=0.5 inches (14mm)
  • Weight 1.2 lbs (544g)
  • Warranty 1 Year
Delorme Street Atlas 2003 Plus
Product: Delorme Street Atlas 2003 Plus
Manufacturer: Delorme
Website: http://www.delorme.com
Price:
Photos:
About:
For GPS navigation software I looked over Microsoft MapPoint and Delorme Street Atlas and after comparing the two, I decided to utilize Street Atlas because of its voice navigation capabilities. For example, if you are lost you can simply ask the computer where you are and it will speak your current location to you as well as give you verbal instructions to get somewhere. These voice features I think are a must when it comes to car-based navigation.
This software also has some other great features such as providing the ability to edit the map. This is great for allowing easy addition of roads, and landmarks, that may not be recognized by the software. These additions can be made very simply via the set of drawing tools included in the software.
Included in the Plus pack only is a greater level of zoom as well as data importing. You might also consider the optional phone data also which would be great for looking up the phone number to the local pizza place.
Features and Specs:
  • XData Import Wizard – easily import your own data from ACT!®, Goldmine®, Excel, text files, or databases
  • Document Linking – tie your map locations to Internet sites, spreadsheets, pictures, or any other documents related to that location
  • Optional Phone Data – nationwide white pages and yellow pages on CDs or a single DVD; over 116 million listings!
  • Document Sharing – use the Transfer tool to quickly and easily e-mail map information to friends or colleagues. Any linked URLs or documents can be transferred as part of the same e-mail package
  • Large-Format Printing – create striking full-size presentation pieces from any plotter with large-format printing capabilities
  • Demographic Data - 2000 Census data including race, age, housing, business economics, and more
  • Detail Level – zoom in one level of magnification higher than our standard product
Equipment Cont..
